Adding a hd/dvr need 10 tuners now | SatelliteGuys.US
FUCCO
58
I want to add another hd/dvr 2line box. However i am out of ports on my multiswitch. If i call directv and they come to my home will they install the box but more importantly upgrade the multiswitch to recieve the ten tuners i need? Is there a fee to get the new switch? IF not do they make a ten tuner output switch i could buy and just hook up myself? thanks
Yes, DIRECTV will make the necessary things happen. What that likely means is that they will split in another WB68.
i called directv last night. They will put the switch in or as they stated make everything work. However there is a $100 tech fee. I asked if they will just send me the switch and they said no. I am better off just buying it on line and doing it myself. I also see the d22 dvr i need as available at best buy so i can get it today. thanks for the info. Anyone know the difference from the r15 and r22 dvr 's
HD LOCALS IN EUGENE, OREGON??
The DirecTV & Dish Merge in September!
