Adding 811 to current 522 setup? | SatelliteGuys.US
santiclaws
22
Adding 811 to current 522/301 setup?
I take it I would not need a new dish or switch, just the 811 receiver itself?
I currently have three TV's hooked up, with a 522 running two of them and a 301 on the third. Self-install would be pretty simple I imagine--just plug in the 811 into one input, the 522 into another (so I'd have HD on Video1 and SD on Video2)--or am I missing something?
Because you already have THREE tuners, chances are you have a Quad LNBF or an external 4-output switch. You should check this (go to Check Switch on your receiver).
P.S. Your thread title should've been "Adding 811 to current 522/301 setup?" :)
You're golden!
Go find the switch. There should be an unused output port. If there isn't, somebody else is using your dish. :D
Actually, if all 4 output ports have cables, you'll have to do a little detective work to find the unused one, but that's easy enough.
Need Replay asap
Question about adding channel
