Add single dish to motorized | SatelliteGuys.US
janzy
SatelliteGuys Guru
126
I would like to add a single dish to my motorized system. I use a Pansat 9200HD running usals to move the Fortec 90cm dish.
Could someone explain how I can do this, please.
thanks
For the fixed dish, the motor setting would be OFF, DISABLE, whatever your receiver says for no motor :)
Also the diseqc switch settings will have to be set for each satellite. As an example on my motorized all the KU sats are set to diseqc 1 and DBS is diseqc 2
On the same topic, I have a Viewsat Ultra on a fixed dish, and have a Coolsat 5000 that I was going to put on a motorized dish.
Would it be better to keep them seperate or would just using the viewsat and switch be better/easier?
Combining them with a Diseqc switch or 22khz switch is easy to do , if they're physically near each other. Just make sure the switch you use is between the motor and the LNBF's .
Pansat 2500A setup question(s)
Focal Distance of a Dish
