Actuator Error No Pulse - Vbox / Analog Receiver | Page 2 | SatelliteGuys.US
Okay, there were a few different issues, but the main issue was mechanical. The dish had some resistance which was causing a bog and over current error. I greased it all up and it made a huge difference.
Also, the AJAX motor seemed to operate funny. It would go then pause, go then pause. I can't figure out if it is designed like this for heat reasons or if it has issues. I was able to get another AJAX motor that looks similar but might be older. It spins non-stop.
Also, the wiring was a little corroded too, but I clean up all the contacts and re-did all the wire tips.
Now the Vbox 6 works great and fits the Coolsat 6000 well, as far as functionality and movement.
So overall:
Clean and grease dish
Check all wires and connections
Check motor. Continuous spinning motor works best
Question about Sonicview HD8000
Special Feed: Lake Champlain Bridge Implosion
