Word @ the office hints at some features from the 922 eventually being available on the 722k, but not the regular 722.
The 722k OTA tuners are likely of a newer generation (at the additional cost) than what is in the 722, which would be an advantage if you are in a "still" OTA DTV challenged area (i.e., now that the transition has occurred and most stations are now at full power and using their planned end use equipment). I found the 722 tuner to be as good or better than what is in the 211 or 222, so if one of those work well for you, the 722 will work as well or better.
What about storage capacity? Doesn't the 722k have a larger HDD?
I've not noticed better PQ, but the menu's do appear to be more sharp. I have to wonder if that isnt the difference in the SW.
That's an interesting observation SubLA. And you can tell it because you have them both hooked up at the same time! I have my 622 hooked to the 63" Samsung Plaszma and the 722k to the 42" only because of not moving receivers and having to spend the time to manually swap all the timers (we used to watching certain shows in the family room, some in the bedroom). No way to move timers so you have to make a list of them and manually add/delete. I can move the shows using an EHD but not the timer.
This will give me the reason to play this weekend to swap the gear and start my migration process. I'll report back what I see on the 63" as I've gotten pretty used to the PQ using a 622 on the 63".
In fact the insides of the 722k and 922 are almost the same. In fact out of the box new the 922 looks and acts like a 722k until it downloads the 922 software.![]()
You know you just opened up a can o worms don't you. Now that we know they are just about the same machine then all of us are gonna want them upgraded after the 922 comes out full tilt.:up
Can the 6 series remotes (6.2 etc.) be used on the 722k ?
Frankly, I dislike the button response on the 21.0 and would prefer to continue to use my existing remotes...
I'm pretty sure that is what the "K" users are seeing. I have a 722 HDMI'd to a brand new 52" Sony K5100 and the Dish HD locals are almost indistinguishable from the OTA locals via the Sony's, latest generation, on-board tuner. SW and wishful thinking I think.
PQ is NO different IMO.
Limited time offer
