Thank you very much! And don't worry, I surely will!Welcome to the world of FTA TheBUDGuy and enjoy your new dish. There is a great group of folks here on this forum, with probably centuries of experience if you add it all together.
Thank you! And I will certainly enjoy it an will be going with a Titanium LNBF as my choice!Welcome to the fold!
I would third or fourth the recommendation of going C band only for now and adding a little dish for Ku later. I spend about 90% of my time on C band, but since SES 3 went online, I've been watching more Cozi and NBC over there on Ku. I would also recommend the Titanium LNB, I use it with an 8 footer and get most everything.
Take your time, pay attention to detail and above all ENJOY.
Thank you! How would I know what size post to get for the dish?Another welcome to Satguys. Also another plug for the Titanium C1-PLL LNBF. Mine works very well.
Be sure you read and read again all the info on getting the correct size post for your new dish. Also purrrrrfect install and you will not have a load of probems. After all, it IS the base of everything.
No unless it is a very temporary mount, never you wood. Wood moves and twists, with temperature and humidity changes. Plus it would not be strong enough, unless it is an awful lot of big pieces of wood and braces and then you would be better off to go back to a metal pole. Check scrap yards and welding shops.He wants to know if he could use wood to mount the dish.
He also wants to know if he could saw the pole at the base of the concrete, meaning the part that's above the concrete.The easy way to remove a pole, is wrap a chain around it, and POP it out of the ground with a lifting it from a front-end loader on a tractor. The hard way is to dig it up by hand, and pull it out and over.
Good to know. One more thing (sorry), he wants to know how many bags of concrete it would take for a pole that holds a 10' dish?If it is long enough to re-use after that sure.
I would drill a couple of holes 90 deg to one another and run long bolts through it though.
This will prevent it from turning in the ground.
Thank you! And one more thing about a pole. My father wants to know if PVC pipe could work? Thick PVC. He would bury it in the ground about 6 ft. Then he would pour concrete in the middle of the pipe to stabilize it. I don't know if that will work, though.Welcome to the SatelliteGuy's family!
Limited time offer
