99w cbs newspath | SatelliteGuys.US
99w cbs newspath
metal head
96
2
The Rock
I used to be able to tune in 99w. I was looking for tp 11771 V 14321, I made two attempts to get it but nothing. Did anything change with that sat? Maybe the footprint.
they moved frequencies a while ago but latelly its been at lower power to pick up.
11785 V 3978 if I remember right
Finally locked it in. What channels should I be getting on this sat. I get AGHAPY which says free but the channel is scrambled. Thanks for any help.
Other than CBS NEWSPATH (if it's up), the only regular channels on there, if I remember rightly, are AGHAPY (of which I don't know what's up with the scrambling either) and AAFES (which has one audio channel in the clear even though it shows up as a video channel.)
best blind scan receiver 2011
FTA Newb...needing some advice
