922 Wireless broadband and EHD | SatelliteGuys.US
schnagner
22
Hello,
Is there a way to connect the Dish wireless broadband module and an EHD to the 922 at the same time, or as there's only one USB port (USB splitter?) do you have to alternate between one or the other all the time?
Thanks for any advice.
Schnagner
There are 2 USB ports, (one on the front, one on the back) but you can also use an USB hub. With a hub be sure it is powered (i.e. has a transformer). You can also have more than one USB EHD with a hub.
"Invincible" Movie on DishOnline.com -***Beware***
ViP211k with old dish 500, 110,119
