922 not mapping down hd channels from 77 satellite | SatelliteGuys.US
drock85
81
Hi I have the eastern arch dish and a 922. For some odd reason today my hd channels from the 77 dish is not mapping down. The 65.1 hd channels are however. I tried restarting the box from the front and even pulled the plug. Anyone else having issues?
Check and see if you still have 77 sat in your check switch matrix. If not , re run the check switch and let the guide load . The 922 seems to only load the guide when the receiver is in stand by . Leave it off for a 5 minutes and it should reload the guide. Also check and see if those channels are blocked under the locks menu. If all else fails pull the plug and reboot .
unbelievably bad customer service - even by Dish standards
problems with Speed Channel HD
