922 master reset | SatelliteGuys.US
922 master reset
surfdevil83
76
Toronto
Well I finally found a 922 for a cheap price. I called and suscribed to the dicovery mini pack and so far I'm happy with it. Now that the reciever is active with my channels, can I still do a master reset to clear all the old channels that don't work? Or will reseting to factory wipe my activation as well. I figured out the hidden menu for the reset but I'm a little nervous.
From what I heard the 922 does not need a rehit for your channels. (but hits are no big deal) You will need to remap the receiver and reprogram everything in though.
You can follow this after you wipe it clean:
NPS - Your One Call Solution
Well I went ahead and master reseted the 922. Within an hour it remapped with out a rehit. Thanks for your advice.
Worth the effort?
Storm Damage and C Band Dishes (among other things)
