9 foot Birdview Dish | Page 3 | SatelliteGuys.US
cell phone related help forum
best place for info on your problem:
www HowardForums com
then, there are other Motorola-related sites, which I cannot comment on
but I'll leave those to you and Google - :cool:
OK. Screw the cell phone. I'm borrowing a camera and will take all the same photos again. I know this one works. I can get them into my computer. Then I'll see if I can get the shots from my computer and to this forum. I'll try tomorrow.
Still trying to post photos. Making some limited progress. Since yesterday I cut the sanding wheel down to a little over 4 inches in diameter. I took a picture of that too.
I plan on doing pictures of the plotting of magnet holes, drilling and gluing.
I am not having much luck finding a reed sensor to buy. I look on the Digi key website and all I see is technical jargon that means nothing to me.
does anyone have a suggestion?
Will post photos as soon as I can.
OK. Let's try the Birdview photos
Let's start with three of them. The first is the dish leaning up against the front of my house and the second is the motor mechanism as it sits on a wheelbarrow. The last is the only Birdview logo surviving on the rig ooops! looks like I only got two in. Better than nothing! More to come if you guys are still interested. I am definitely open to input and suggestions.
Still need to order the right reed switch from who knows where.
C-Band feedhorn part: what is this called?
C-Band circular polarity
