9/11/2009 2:25pm - Uplink Activity Report - 35 changes | SatelliteGuys.US
D
DigiDish Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 9/11/2009 2:25pm - 35 changes
Uplink Comparison Range: 09/11/2009 02:04P - 09/11/2009 02:24P
Channel Removals:
5932 - SD13 (NA) removed from Echostar12 61.5W TP 23 ConUS beam
5933 - SD14 (NA) removed from Echostar12 61.5W TP 23 ConUS beam
5934 - SD15 (NA) removed from Echostar12 61.5W TP 23 ConUS beam
5935 - SD16 (NA) removed from Echostar12 61.5W TP 23 ConUS beam
5936 - SD17 (NA) removed from Echostar12 61.5W TP 23 ConUS beam
5937 - SD18 (NA) removed from Echostar12 61.5W TP 23 ConUS beam
5938 - SD19 (NA) removed from Echostar12 61.5W TP 23 ConUS beam
5939 - SD20 (NA) removed from Echostar12 61.5W TP 23 ConUS beam
5940 - SD21 (NA) removed from Echostar12 61.5W TP 23 ConUS beam
5941 - SD22 (NA) removed from Echostar12 61.5W TP 23 ConUS beam
5942 - SD23 (NA) removed from Echostar12 61.5W TP 23 ConUS beam
5943 - SD24 (NA) removed from Echostar12 61.5W TP 23 ConUS beam
5944 - SD25 (NA) removed from Echostar12 61.5W TP 23 ConUS beam
5945 - SD26 (NA) removed from Echostar12 61.5W TP 23 ConUS beam
5946 - SD27 (NA) removed from Echostar12 61.5W TP 23 ConUS beam
5947 - SD28 (NA) removed from Echostar12 61.5W TP 23 ConUS beam
5948 - SD29 (NA) removed from Echostar12 61.5W TP 23 ConUS beam
5949 - SD30 (NA) removed from Echostar12 61.5W TP 23 ConUS beam
5950 - HD1 (NA) removed from Echostar12 61.5W TP 23 ConUS beam
5951 - HD2 (NA) removed from Echostar12 61.5W TP 23 ConUS beam
5952 - HD3 (NA) removed from Echostar12 61.5W TP 23 ConUS beam
5953 - HD4 (NA) removed from Echostar12 61.5W TP 23 ConUS beam
Channel Moves:
5920 - SD1 [MPEG2 SD] moved from Echostar12 61.5W TP 23 ConUS beam to Ciel-2 129W TP 32 ConUS beam (NA)
5921 - SD2 [MPEG2 SD] moved from Echostar12 61.5W TP 23 ConUS beam to Ciel-2 129W TP 32 ConUS beam (NA)
5922 - SD3 [MPEG2 SD] moved from Echostar12 61.5W TP 23 ConUS beam to Ciel-2 129W TP 32 ConUS beam (NA)
5923 - SD4 [MPEG2 SD] moved from Echostar12 61.5W TP 23 ConUS beam to Ciel-2 129W TP 32 ConUS beam (NA)
5924 - SD5 [MPEG2 SD] moved from Echostar12 61.5W TP 23 ConUS beam to Ciel-2 129W TP 32 ConUS beam (NA)
5925 - SD6 [MPEG2 SD] moved from Echostar12 61.5W TP 23 ConUS beam to Ciel-2 129W TP 32 ConUS beam (NA)
5926 - SD7 [MPEG2 SD] moved from Echostar12 61.5W TP 23 ConUS beam to Ciel-2 129W TP 32 ConUS beam (NA)
5927 - SD8 [MPEG2 SD] moved from Echostar12 61.5W TP 23 ConUS beam to Ciel-2 129W TP 32 ConUS beam (NA)
5928 - SD9 [MPEG2 SD] moved from Echostar12 61.5W TP 23 ConUS beam to Ciel-2 129W TP 32 ConUS beam (NA)
5929 - SD10 [MPEG2 SD] moved from Echostar12 61.5W TP 23 ConUS beam to Ciel-2 129W TP 32 ConUS beam (NA)
5930 - SD11 [MPEG2 SD] moved from Echostar12 61.5W TP 23 ConUS beam to Ciel-2 129W TP 32 ConUS beam (NA)
5931 - SD12 [MPEG2 SD] moved from Echostar12 61.5W TP 23 ConUS beam to Ciel-2 129W TP 32 ConUS beam (NA)
Transponder Changes:
Echostar12 61.5W TP 23 ConUS beam 20000 QPSK 5/6 removed
Channels in the system: 6632
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
D
9/2/2009 4:55pm - Uplink Activity Report - 29 changes
D
9/9/2009 1:31pm - Uplink Activity Report - 27 changes
