811 Caller ID Doesn't work | SatelliteGuys.US
Nicko23 said:
Should the caller ID on the 811 work? I have it enabled, but have never seen it work....
Mine works just fine.
(Possible dumb question alert) Do you have that option setup with your phone company? It costs me about $7 extra per month.
Yeah...of course, how can someone live without it?
Mine works fine, as mentioned, you have to have it enabled from the phone co, and you need a phone line connected to the reciever. If you are using perhaps some sort of wireless phone connection or some other remote phone line connection device than a wired direct phone line, some of those devices do not work with caller ID.
It also shows up between the 1st and 2nd ring on mine.
Check all the obvious mentioned before, mine works fine.
Those of us stuck in the Middle Ages manage. I kind of like the old way, where people don't interrupt me when I'm talking and wait their turn.
Different strokes ...
If you're talking about CALL WAITING (where when you are taking on the phone and someone calls, then you hear a beep), then I agree with you.
But that's a different animal! :)
I love knowing who is calling so I can ignore all the telemarketers!
Ack
Senior moment
I'll mess around with it tonight. Only thing I can think of that might cause it not to work is I have one of those adapters in the phone jack so I can have a couple phone lines going in there (1 for phone, 1 for 811 and 1 for Tivo).
Test the line with a known working phone, also make sure you can dial out, make sure the 811 has caller ID enabled.
Do the telephone line test on the 811. It will tell you if it sees dialtone.
Do all of the video outputs on the 811 carry the Called ID info? I mention this because on both the 5000 and 508 receivers that I have owned, the Caller ID is not present on the Video 2 output so as to prevent having this info appearing on a video tape recording.
Just a thought.
Jerry
Receiver Phone Home Frequency?
Is there any hope for HD DVR for my setup?
