Those were at full zoom and the 2 inside were Normal...(and as you can see the sides were cut off much like a Fullscreen dvd vs. a Widescreen. I have more options with the 921 as you can see on post 28 (I had a 6000u that had pretty much the same options as the 921, but it died)ride525 said:Dfergie, when you posted the 4 pictures on post #27, what did you do to get the output to fill your TV scren (Pictures 1 and 4)? Are those pictures cut off on the left and right side?
you can use the zoom on the Panny if it is so equipped or the differant aspect ratio's on your TV to get full screen...ride525 said:And you have a Panny DVD recorder. I am looked at the Panny EH-50S, and wonder what I can do to get a full screen like you did on post #27, pictures 1, and 4.
Thanks for your help.
Limited time offer
