722K with a 6.0 UHF PRO Remote | SatelliteGuys.US
uptownvideo
178
13
Do any of you know if a Dish Remote 6.0 UHF PRO reomote control will work with a 722K receiver? Thank you in advance.
I just figured it out. I had to change the remote address on the receiver to a 13a. It was on 14b. Now it works fine.
New to these things. Can you pls. walk me thru how you changed remote address on the receiver? I have 21.0 remote which came with 722k which I am using in one room. I have an old 6.0 Ir/UHF pro remote which I would like to use from another room, but do not know how to change its remote address. Pls. help.
Enter system info screen by pressing the menu button twice.
Hold sat down until all mode lights light up.
Type in a number, press pound.
<this sets the remotes address>
Press the record button on the remote you just set.
<This sends the signal and programs the rcvr to respond to that address>
Write down address of the remote #2
Hold sat down on your 6.0 remote, until all mode lights light up.
Type in that address number in your 6.0 remote, press pound.
Press the record button on the remote 6.0 you just set.
Thanks, this really helped and I am in business using 6.0 remote with 722k DVR from my other room:)
NHL Center Ice vs. NBA League Pass on Dish
Snow on my dish 1000.4
