722k stuck on fast forward | Page 2 | SatelliteGuys.US
Does F-FWD stop as soon as you disconnect the antenna or do you need to disconnect the antenna then stop it using the IR remote?
I think it would go until I hit stop with the IR after unplugging the antenna.
I've been going through the channels to find a "dead" one, so far channel 5 seems to be working without the issue.
Issues with older receivers
