I think there was only one OTA port on the module. The other was the TV1 distribution out port.
Is the TV1 distribution out port to allow you to send the OTA signal to another input on your TV instead of splitting it before going in the 722K?
Distribution of the TV1 output, of course!In that case, what is the TV1 distribution out port on the OTA module for?
Distribution of the TV1 output, of course!Whether it still has a passthrough function, I have no idea.
So just another way to connect TV1 instead of using composite or HDMI, correct?
Hey, quick question.
Is there any way to manually set or change the tuner on a future recording? For instance, I'm recording Hung/Entourage and In Plain Sight on Sundays and I'd like to swap their tuners from what they currently are by default
Physically there is nothing you can do about the signal change. It is whatever the station is sending out AND what they can send to you is only what the program has to offer or what they choose to send. It is not a DISH thing nor can it be "fixed" technically by DISH or any provider. They're just passing on the channels audio as it comes to them. When the type of transmission changes, things will happen and I would imagine that this early in the game most receiver manufacturers have not realized or addressed this issue yet. But they'll have to. Unfortunately, since it is so close to the "transition", not all programming conforms to DTV standards and since there are still many SD sets, SD programming and channels (Still. I Know!) out there it may be a while before it does. That means station ID logos (God I hate those!!!!) and D.O.G.s (Digital Onscreen Graphics - REALLY hate those) will be set up for SD and be in the middle of your beautiful new HDTV picture. This also means that audio that has always been a second thought will only be HD/5.1 if they have the programming, money to do so or the intelligence (not seeing much of that) to step up. Also I see that during transitions to and from commercials, even it they have 5.1, there is no audio sent at all, so that null period is a signal change to the receiver, just as when you skip or etc. That's just a way of life.i have a 722 not a K model and i get pops every now and then skipping through commercials and such. i have my audio going through toslink to my receiver so i'm not sure what the problem is either. wish they would fix it though. kind of annoying.
Yes, they are.I have the install scheduled next Saturday for the VIP 722k and was wondering if all the outputs for tv1 are active simultaneously ?
Yes, they are.
No issues if you want to hook up another TV, SlingBox, or something similar.
Limited time offer
