At that range, they probably will, but less than using the entire East face of the roof as a reflector, channeling noise into an antenna that isn't properly polarized.
How deep is that eave?
I was going to cement the base and use a standoff on the eave (for securing/stabilizing) the top half...
DISH does carry the channel. I get full guide information for that DISH channel, but the same OTA channel I get "Digital Programming". All the other *.1 channels I get have guide data that matches the DISH equivalent except 19.1 (Which I watch frequently ie. Survivor, etc.).The fact that an OTA channel guide doesn't work doesn't suprise me if it's a channel that Dish doesn't carry. I get no guide data for one of the religious channels (5 subchannels total), and I also get no guide data for my THiS channel (29.2), even though CW (29.1) is carried by Dish and I get full guide data for them.
I have one of those in the Washington DC DMA: WPXW, our local Ion affiliate. I would really like to see the guilde for the digital subchannels. But alas, that and the main channel are all "Digital Service", and have been since the transition.DISH does carry the channel. I get full guide information for that DISH channel, but the same OTA channel I get "Digital Programming".
Ok I've changed my mind again...lol
What I am going to do now is get a 4X4X16 post, dig a 2 foot hole, concrete the post in the ground then get some 1 5/8" pipe and mount it to the 4X4......
That way I can mount the antenna any where I want........lol Take that multi-path!
4X4X16 is the correct syntax according to the lowes website. - http://www.lowes.com/lowes/lkn?acti...61544&Ne=4294967294&Ntk=i_products&Ntt=4X4X164 inches by 4 inches by 16 inches? Hows that gonna help you? Or do you mean 4 by 4 inches by 16 ft ?
Limited time offer
