722 problems caused by latest software>>> | SatelliteGuys.US
bnewt
1,488
550
Shepherdsville, Ky
Has anyone experienced lower sound volume on SD channels & audio output from tv2 is now mono only, since the latest software update? The lower sound on the SD channels would probably be beneficial since the HD volumes are reported the same volume, bu, one of the "advantages" of the 722 is the stereo output for tv2.
My tv 2 to my computer room shows stereo on both tv 1 and tv 2 over coax. Yes, I like the sound equalized now between hd /sd channels. Use the RF mode under the dolby digital menu and the tv 2 will sound louder. Rf (coax) is always louder than the line mode( rca jacks).
Don't recall reading any specs on 722 offering MTS. Stereo available for tuner 2 using composite, yes.
Stereo for tuner 1 & 2 via coax/home distribution
Same here... TV2 in master bedroom off 722 has always been stereo. A feature that I think ALL sat boxes should have, on the RF output. Now, if they'd just make it output an ATSC signal, I'd be a happy camper!:D
What do I need to add an additional Dish receiver?
DishHD Absolute Question
