721 Clock off by 1 hour | SatelliteGuys.US
JonUrban
578
Eastern Connecticut
Is there anyway to correct this? The guide looks correct (right show is on say, for 6:00, but the guide and time say it's 5:00)
I tried a check switch and nothing changed.
THANKS
THANKS
My 510 had an issue with the daylight savings time change when you get an upgrade perhaps your issue will be solved also. :confused:
Just wondering did you ever get it solved.
I have the same problem. The clock hasn't been right since the new daylight savings time. I'm hoping that it will correct itself when the traditional daylight savings time would start.
Scott
Last weekend would have been the normal date for the start of Daylight Savings Time.
I checked the clock on my 721 last night, and it is correct now.
Scott
Any word on the street
HD locals on DISH
