6X8 Multiswitch Question | SatelliteGuys.US
guapoharry
1,423
32ºN 111ºW
One of SG's Gold Sponsors has a Zinwell 6X8 multiswitch for sale on their website.
The diagram shows three dual LNBFs hooked up to it. However, the wording says, "This switch allows you to to combine signal from two satellites and install it on up to 8 satellite receiver. See diagram below!"
I can't imagine how one would program a receiver to use three LNBFs unless it used DiSEqC instead of 22khz...
Is the diagram in error, or can you use it with three LNBFs?
a couple of their diagrams are wrong. Here is another
that wont work as what happens if on the "slave" multiswitrch (the 3x4) you have 3 receivers that want
-one on a V transponder
-one on a H transponder
-one on the 2nd LNB (hooked to 22k)
switch cant support that
Uniden Supra Analog Receiver
