625 311's one coax | SatelliteGuys.US
625 311's one coax
keeletronix
79
5
Texico, Il
can ant one help me with this problem 625 two 311's one coax to each room
i need to know what to do to hook these up they are no going to hook up tv 2 using pip thanks !! :confused: :confused:
No idea what the second lne is asking, but the only way to deal with a dual-tuner, one coax situation is a DishProPlus switch or LNB.
Because you need three feeds, a DPP-Twin ain't gonna do it for you (although if you had a 322 instead of a pair of 311s it would).
So, you need to get an (expensive) DPP44, or run that second coax to the 625.
You will need to split the tv 2 output from the 625 with a 3 or 4 way splitter depending on how many tv's you want it to go to. The coax lines coming from the splitter will need to go to the 311's and connect to the antenna port to allow you to view the tuner 2 output. If you want pip then your tv would have to support this by way of multiple coax and rca connections, the 311 will not provide pip through itsself. The only other way to get pip is by setting up the 625 in single mode for the tv its on or to go with other types of dual tuners such as the 322, 721, 921, 942, these would be the easier way to do it but will cost more.
Diseqc Dishnetwork
625 Audio Question
