622 via HDMI --no volume. | SatelliteGuys.US
losar
11
Hi
I just hooked up my 622 with my hdtv last night. It was working fine. This morning I get picture but no volume.. Does this mean I have defective HDMI.
How do I check what version reciever I have.
You need to tell us more about your hook-up. Are you just connected to your TV or are you coming out of it to a receiver? Have you tried the fiber optic out? Re-seated the HDMI?
So you get audio from TV only? Might want to check and see in your TV settings if internal audio is set for ON. Have you re-connected the cable? HDMI is NOT the the snuggest connector/plug. If still no go, it's either the port or the cable, probably the port.
My TV seems OK--replaced VIP622 once for no HDMI signal just stopped. My DVD recorder (RCA DRC8060N) passes the HDMI signal when recording but on playback there is no sound into Samsung HL-S5687, even 2 channel.
So no accounting for HDMI and sound.
-Ken
Controlling my Optoma RD50 television
Audio Drop out
