622 Signals Screw Up | SatelliteGuys.US
ralfyguy
3,242
437
McAlester, Oklahoma
After the l3.65 update, many people reported low signals on 129/61.5. I observed that it isn't just tied to those sats. In fact, when the signal is as low as 76, and then dr,ops d,own another pointv, it'll jump down to 64, then rises another point and jumps back to 76. Anything higher or lower will be displayed normal. For example 76+ will count normal, and 64- will count normal. Question is, is this just the display for the user, or is it the actual signal strength the receiver works with? I noticed the same phenomenon on TP17/110, whereas the rest of the TP's on 110 are high 80's to high 90's. So it isn't tied to the 129/61.5
Now that you mention it, I saw the same thing on a 622 (friend of mine). We were checking 129 and can't remember the TP but when it would jump from 64 to 76 all the time but the other TPs were displaying the normal reading. The other TPs had higher readings.
More E* HD bad news!!
Need help with Quadshield Coax
