622 OTA Antenna HELP! | SatelliteGuys.US
AUTIGERS1101
53
Huntsville, AL
For the past month or two we have not had OTA HD on the 622. We have 2 622s, and the other has not had any problems with HD OTA. I thought it might be the antenna, so I hooked up the other 622s antenna to try with the messed up one. It didnt work either. I tried deleting all the OTA channels that used to work and searching for them again, but it can't find any. does anyone know what might be the problem?
If the errant ViP622 doesn't work in place of the working ViP622, it is likely that the tuner has gone away. If this has happened, the receiver will need to be replaced.
Time on my 722
HDMI version
