I don't think the 622 HDMI passes 5.1. Try using the digital audio output from the 622 to your receiver.I have a question about homw theatre setup , I have a panasonic home theatre and a 722 my tv has 2 HDMI's one is running to the home theatre and the other to the 722 and h. theatre is on AUX 5.1 surround sound doesn't seem to be working more like 3 speakers centre and front 2. what am I not doing? I usually just manually turn the other 2 by selecting music surround that turns on all 5 speakers.
I suspect your cableing is wrong. Check you manuals. The HDMI from TV to receiver does not sound right if you don't have the 722 going into the receiver. The two HDMI's on your TV are INPUTS. With 722 going to TV, you should have optical/digital out from TV to receiver.HDMI does support 5.1. Check the settings. They can be affected by the receiver and the TV controls.
HOWEVER, it think by putting that DVI in the middle, you might lose the capability to pass digital audio (DVI is video only, correct?) I am not 100% sure about that DVI part.
Lots of confusion here. First, DVI is video only. if you have DVI in the chain, then no audio.
We don't know that will be the case at all. It is very likely that the external hdd will be tied to the receiver (not the account). So if your receiver failed and was replaced you would lose the content on the external hdd as well.
You are able to connect your external drive to a replacement 622/722 without loss of recordings. For now, there is a limit as to the number of times (I think it is three times for now) this change of DVR will be supported. In the future, we will be able to move the external drive between any VIP DVR on our account as often as we want. Do not know when that change in software will be rolled out.
I just moved my external drive from one of my 622s to a newly added 722 without any problem.
Limited time offer
