6 Hoppers? | SatelliteGuys.US
6 Hoppers?
I don't know if it's so or not, but a Dish CSR told me one time that 5 hoppers was the limit. Like I said I don't know if that is true.
Why would you need 6 hoppers on one account ,unless you are charging for your own mini cable company to renters on your property.
I too remember 3 cascaded DPP44's being OK. So, that means you've got 12 DPP outputs, which could in principle go to 8 Hoppers without even adding dual DP LNBs to feed two sets of 3 DPP44s.
Mmmmm . . . the CSR I just talked with said 2 Hoppers is the max.
I wonder how many different answers we can get.
Did you mention they would be purchased? 2 hoppers is max for leased.
Glad you mentioned this . . .
I tried calling again and was given this #: 800-333-3474.
The person I talked with said DISH "usually" stops at 16 receivers!
I asked the rep to please check this . . . she came back with 2 leased + 5 purchased Hoppers for a total of 7.
I'll bet 8 wouldn't be a problem.
Reactions: TheKrell
8 would likely be more than the 3 DPP44 could handle, but even outside that, that would be the first install to be audited. And likely audited multiple times... Just some words of advice.
Reactions: navychop
Kind of funny that when the CSR told him 7 was max, he wanted to come up with 8, but just for technical reasons. Cool your jets, just kidding:biggrin.
It's interesting you brought up the 44 switches. What's possible and what the manual says are very different. The manual says 3. The apartment buildings I go into sometimes say 12, or 15, or 20. :/
When is team Summit?
Can Joey be Used with Dish 211K Receiver?
