I dont know if this will help any but here is what my actuator looks like on my 6 ft dish.
Very good response, Rob! :upYou are absolutely correct. If in fact they are missing parts, please let us know. For the most part, we have extra parts that we can send to you right away.
I apologize for any inconvenience it may have caused any of you.
You got that right, Stogie. The PM24 actuator is also pretty large for this little dish. I had to really "choke up" to get a decent traverse and limit the amount of arc per extension of the rod. I'm back with the original bolt to fasten the actuator to the dish, and mounting the rod end on top of the dish bracket ( won't fit below ). The actuator pivot is mounted top side of the angle bracket with spacers so it will clear. Gives a fairly straight push and pull, plus the shorter bolt keeps down the flex. I was getting a lot of movement with the long bolt. Couldn't be mounted rigid enough to repeat positioning.After sleeping on it, I think I will flip the bottom angle bracket over, and just use washers to make it right, its about all we can do. I am a firm believer in making that actuator push and pull as straight as possible.
I haven't really had much interest in these dishes before, but going back and reading what Robbie put in the original thread, this dish was never intended to have an actuator, so it wasn't designed to take one.
Won't be the first time we FTA guys had to adapt something, right guys?
"PS: brentb636, I like the camo paint job (little dots) on the back of the dish.
Any particular reason? Surely not that many paint blemishes. "
I wanted the underside dark, but not solid. No sense having the white back of the dish tip off the satellite police. This dish is installed in a non-locally approved location ( actually all my dishes are non-approved ).![]()
The local satellite related ordinance dates from 1987, so it's somewhat out-of-date, but no sense getting authorities involved if they don't need to be. Better to ask forgiveness than ask permission.
I goofed!! Sorry! It do get RBI international on 3995V2220 for my only 24/7PA Cable network is on AMC9 (83W), so I assume it moved from AMC6. With no tp active, it's hard to position to get this bird !![]()
Limited time offer
