522 Recording | SatelliteGuys.US
522 Recording
zexel
10
I am using the 522 with one sat feed on tuner one until I get my superdish installed. It is in single mode. It will not record any timer events. I don`t know if it is trying to record on tuner two or what, anyone with an answer?
322 & 522 are supposed to have both tuners connected to the dish from day 1 be thankful you can watch TV. :)
I had a 522 connected to only a single Sat feed for a few weeks and it just worked fine. Just don't expect PIP or multi-tuner/Recorder type functions to work. FYI - I don't believe that setting the 522 to Single MODE will do anything for you with only the one Sat input.
I'll assume that basic recording works for shows you're watching? If not you got bigger problems than timers. Anyway, check your DVR set-up preferences and see how you have them configured.Check the following: Select Menu>Preferences>Record Plus and set Activation=Enable and Preference=TV1. Can you set a timer now?
Black screen
I hadn`t tried to record except for timers. I did and it says it`s recording and there is a program in the recorded programs list but when you try to play it it is just a black screen, but you can hit the browse button and get the title.
try setting the record plus option to tuner 1. that might help you out. im not sure as the unit isnt really supposed to work at all with only 1 tuner.
DVR - problem with delayed mode
New 921 DOA - Sort of...
