4 HD 211 receivers | SatelliteGuys.US
4 HD 211 receivers
I would switch out the lnb with 3 dp duals or singles. The switch in the 1000.2 and the external switch can interfere with each other and eventually one will fail. You will also need a "W" bracket for the duals/singles. I know the manuals say the lnb is compatible with an external switch, but not in practice.
lost signal in the morning
upgrade
