4.2.2 ???? | Page 2 | SatelliteGuys.US
4.2.2 ????
i have a cw and it don't get all the tps it has a signal but no quality and i add the tps from the list and lygnsat
yeah its a mesh 7.5 ,,,,,,,, another problem i can not get channels at all on the azbox elite,,lol
what up with the go go list for west satellites???
Jeff, Just my 2 cents worth...I had a six foot Fortec dish and had issues getting several channels...including some S2. I now have virtually the same dish set up only it's now an 8 foot dish. I noticed a big improvement on most signals. Most of the weaker stuff came up another 5-10 points. Some of the weaker
s2 stuff I still don't get though. I also had the same LNB and switched to a the Geosat combo C/ku lnb last year. The change in the lnb also seemed to help. Perhaps you might change the lnb first and try that. Just my opinion, others probably have better experience with this than myself. Blind
can i just take down the 7.5 mesh dish and put a 12 foot fiberglass dish in its place and use the same motor?????
RIP 922
Best heavy duty actuator?????
