39" SATELLITE DISH+SG2100 MOTOR+QPH031 QUAD LNB | SatelliteGuys.US
TVBobby
15
I am thinking of getting this settup
I have a BUD and there are two adjustmants on the BUD.
The one you tune in the Sothern most sat. and the other is to tun in the E and W sats.
With these 39" dishes with motors. Is that adjustment on these also.
Do I first tun in the sothern sat. and that is it or do I also have to do the tunning of the E and W sats?
Also I have a SONICVIEW 8000. Is all I need to run the motor ie a 1.2 Discq swith? And enable that motor option in the menu for that sattilite and fine tune the azimuth?
I guess what I am asking is can someone give me the full satilite tuneup proceedure for a 39" motorized dish and if possible the menu setting for the 8000?
Bobby
Bobby,
You may need to start your own thread for your questions. A lot of people used to read Newbies Gone Wild, but I think most are now waiting for my next project.
The only thing I can tell you is that I will never again try to push a 4 foot dish with an SG2100 motor. I'll bet it will work fine with your 39 inch dish.
Mast side
The Newbies: Me and son #3 (age 18).
The Counselors: Various senior members of SatelliteGuys.US
Counselors advise, "Get a 36 inch dish, easy to start with, get some FTA up and running for family enjoyment."
Newbies meet with Mom and reason, "They tell us 'rainfade' can occur, and we may be moving to Oregon or Washington. Let's get bigger"
Counselors advise, "Start out simple without motor."
Newbies and Mom decide, "Climbing up to the roof and reinstalling later will mean more suffering in 112 degree Nevada heat. Just install the motor, but don't *run* it until we figure everything else out."
Counselors advise, "Install at ground level first, keep things simple."
Newbies already excited, do not see the post until later. "Let's build a wall mount."
Photos below look like Newbies succeed. Don't be fooled.
Advice to other newbies; DO WHAT SENIOR MEMBERS ADVISE... they don't call them "senior" for nothing!
Is that a 2" mast in the last picture?
Bobby,
Cool. Thank you.
BTW is it true you HAVE TO HAVE a disqu 1.2 motor switch to operate tha motor?
I just got a Panasonic 37" dish with a PM900S motor. The man I bought it from said he did not use a Disqu 1.2.
I thought you had to have one to operate the motor.
If so can you point me to a place to buy one and should I put it near the dish?
TVBobby,
You should start your own thread for more / better answers.....
You are "mixing" a DiSEqC Switch and DiSEqC Motor
DiSEqC = Digital Satellite Equipment Control, it's a set of Standardized Commands that a DiSEqC compliant Sat Receiver can send over the cable to control DiSEqC compliant equipment, switches motors. Think of DiSEqC 1.2 as DiSEqC Level 2, more advanced than Level 1.
You do not need a DiSEqC Switch to use / control a DiSEqC Motor
You should look up "USALS" for motor control
Scored a Primestar dish
switching out recievers
