322 remote with TV/DVD combo | SatelliteGuys.US
VCR mode is a plus...
In my experience 9 out of 10 homes I goto with combo units do not program to the DISH universal remote.
In the owners manual there is just a handful that are supported.
did you try auto scan by pressing TV button until all light are on then bigger red power button after that scan up until TV turns off, this usually works on TV/VCR usually Magnavox are the worst
I think that I recently ran into one of these machines and found no code. What you need to do is to program each of the tv codes for magnavox then instead of trying the power button try the volume button to see if you can control the volume. If you are lucky then program the vcr codes to see if any will turn the unit on/off in the vcr mode. It takes time as Magnavox is a whore of remote codes.
Legality of Dish Network in Canada or Mexico
811 loses OTA Programming Info - What about 211 and 622?
