322 Inactivity Timer? | SatelliteGuys.US
trinidex
892
Does the 322 have an Inactivity Timer?
Checked an installation this morning and it had "Press Select to Continue" on the screen.
I setup a ViP211k and in the menu there is an Inactivity Standby option (Preferences).
I can't find this option on the 322.
Anyone know how to stop this from happening or a workaround?
TIA
Further reading indicates this is happening because of the daily early morning updates.
Can someone confirm this?
TV2 on the 322 you cant turn off that "press select to continue" option. As soon as the power off is engaged it goes to that
If you leave it on all the time it still will do that. Found that out the hard way on both tuners
All American Direct freezing.
Question about a failed experiment
