D DAJohnsonGymDawg Member Original poster May 10, 2007 11 0 Aug 1, 2007 #1 Can anyone tell me if there's a program that can determing if any other spot beams than the Atlanta spot beam covers my area.
boba SatelliteGuys Master Dec 12, 2003 11,350 1,036 Dorchester, TX. Aug 1, 2007 #2 DAJohnsonGymDawg said: Can anyone tell me if there's a program that can determing if any other spot beams than the Atlanta spot beam covers my area. Click to expand... Go to menu6-1-1 and check different transponders on 110 & 119 it will indicate signal strengths and wether it is a spotbeam or not.
Cyclone Proud Stiff Member Supporting Founder Sep 9, 2003 2,586 16 Maryland Aug 1, 2007 #3 Good stuff here. The Echostar Knowledge Base on DBSTalk
B BobaBird SatelliteGuys Pro Sep 8, 2003 1,693 0 EKB Annex Aug 8, 2007 #4 Specifically, Spot Beam and Coverage Maps
M Mr Tony SatelliteGuys Pro Supporting Founder Nov 17, 2003 3,466 15,202 Mankato, MN Aug 8, 2007 #5 and I think you meant zip code
chaddux Insert Clever Phrase Here Supporting Founder Sep 19, 2004 1,847 26 DMA 114 Aug 9, 2007 #6 Iceberg said: and I think you meant zip code Click to expand... It's one of those new five-digit area codes. "Introducing 12-digit dialing!"
