2700 menue- set up? | SatelliteGuys.US
2700 menue- set up?
catman60
SatelliteGuys Guru
132
michigan
just trying to see if this old 2700 will give me 119 and 110. i have a dish 500 with the dp twin not dual lnb. when i go to set up it says super dish-3 sat,4sat,full,alt.. 119 comes up but no 110.i tried switching tp's but still nothing.all it says is satellite 119,polarity odd for input 1. it shows a x for the second input 1 and then xx for the next 2 inputs which are labeled 2 and 2. i did test switch even though i don't have a switch.i just seems like the 2700 is made for a superdish and not a 500.
The old receivers with 4-digit model numbers don't know how to handle DishPro LNBs or switches. You will need a DishPro Adapter in order to get that to work right.
RV set up (2 HDTVs running on HDMI w/ Splitter)
six foot dish on 2.5" steel pipe?
