211k with built in G3 card | SatelliteGuys.US
caboclipper
59
I just purchased a new 211k I called dish to activate it. I asked if they would send me a new smartcard for it. They say that 211k's do not need it, that they have it built in.
So I just wanted to share this with everybody. (Probably everybody already knew this but me)
Does somebody know what model numbers others than the 211k have the G3 card built in as well ?
Best regards
its easy to check. go to
Menu 6 1 3 NEXT then Next again
until you see DNASP
if your box says 206 or less then you will need a new smart card.
if it says 241 then everything is ready to go no card needed.
Wireless via USB on vip 722?
Opinion sought on SD upscaling
