211K trying to record | Page 2 | SatelliteGuys.US
IIRC Dish added a setting where the HDMI detects that the TV is off and automatically turns the receiver off.
I think there is a setting in the menus to disable this "feature" but I no longer have a 211k so I can't check.
BINGO! You get the gold star Jim, I looked & found that setting under tv enhancements! Thank You!
The setting is for allowing recording to a external device, either on or off!
I appreciate all the comments on here from people willing to help!
That setting is to control certain VCRs through the A/V conection (starting and stopping) the recording by the timer on the 211.
I tried it out with my original settings using HDMI from recorder to TV, RCA cords from receiver to recorder, HDMI from receiver to TV & it works perfectly with the TV either on or off! Thanks again!
Reactions: TheKrell
All well and good, but I would much prefer recording true HD on an EHD. Different strokes....
Depends. If you want to keep the content beyond the life of your account, then DVD in SD (or a Hauppauge in HD) is the way to go.
Most of the stuff that does come back around is crap anyways. :) Of the very little content worthwhile keeping isn't worth taking the risk.
Problems with Dish Anywhere
Dish Network still sending out 722s??
