211 upconverting? | SatelliteGuys.US
211 upconverting?
bentjm
2,899
1,651
The data sheets on Dishnetwork for the 222, 612, 722, ... all mention that the receivers upconvert SD to HD.
The data sheet on the 211 does not state that it upconverts. Does it upconvert or not?
The 211 as does the 622 and the 722 outputs one resolution that is set in the menu.
If you set it to 480p all output is 480p. If you set it to 1080i or 720p that is the output for all programming on the HDMI and component outputs, so in that case it is upconverting everything to the output setting.
Dish Earning Conf Call Monday 8/4/08
OTA Antenna into DISH vip 722
