2 HR22's | SatelliteGuys.US
2 HR22's
sobonefnet
322
2
PA
OK so I have 2 HR 22's. I have downloaded CE to both. Now, how do I get MRV to work on these?
Multi-Room Viewing (enable with keyword search "MRVCLIENTON")
Menu, Search for shows, Keyword, do search, when no results found hit done.
Settings are controlled via the Location menu on the system setup.
Also do the Keyword search IAMANEDGECUTTER to enable the Misc. Options menu which can be used to turn it on/off.
They also need to be connected to the internet.
No internet needed. I just run a normal 1 meter cat5 cable from the lower ethernet plug on the HR22 to the HR20.
The lower ethernet plug on a HR22 acts as a router.
Performance
need help with MRV
