18"- 3 lnb and 2 tivo's | SatelliteGuys.US
tach18k
36
I currently have a 18" 3 lnb dish with 1 tivo and 1 standard rec hooked to it. I want to add another tivo. Is there room or is it easier to use my old dual LNB for the new tivo?
If you local channels come from 119, then the old round dish (101 only) will not be able to see them on your new tivo.
The other option is to obtain a 4x8 or 5x8 cascadeable multi-switch to connect the four lines of your PhaseIII dish to, giving you a total of eight new outputs.
D* HD Receiver upgrade
Samsung 360 or RCA 210
