137w | SatelliteGuys.US
137w
crankbait
37
i've been trying to find 137w amc7 on my 6 ft dish on 4080 h 29125 can't find it, i live in ohio have found 103 and some others ok. i was wondering if 137 is still working. thanks for any reply
thanks for the reply, i was going by the numbers on the list
You need to note the last time that list was updated. That TP you're looking for was active back in 2011 but it's not now. Your best bet is that 4000 lukin mux that Magic mentioned up the page.
All should be careful about recommending The List. It is OK in general, but that's not good enough for its intended purpose. I prefer other references, or to use a combination of many sources bouncing each off the other.
AUGUST 3 2013 UPDATE Mike does a heck of a job, My hats off.
worldwideweb sathint dot com ain't bad either.
TheList (here)
Lyngsat.com/america.html
I many times look at 'em all and, like cyberham, bounce 'em off one another.
If listed 2 out of 3, can bet it's there.
i changed the numbers but still can't get a signal, i have a coolsat 7100, do i need a different reciever. i have a clear view no trees in the way.
the transponder I posted above is DVB and the CS7100 will work fine
The Luken mux is DVB-S2 and will not work
How to hook up 3 receivers
Free Used Equitment needs a Home
