129 or 61.5 - That is the Question | SatelliteGuys.US
Y2k06
SatelliteGuys Guru
123
I can't seem to get a straight answer out of any of the Techs on which bird to aim to?
No argument on 110 / 119. That one doesn't change.
Have been told (BTW - I'm in North Texas) when I got my 211 to swing 2nd dish from 148 over to 61.5 for HD/Voom, which is how it's set now.
Then, I call for some help as the angles given didn't work, (got that sorted out) and he says, Use 61.5 for now, but Feb 1, put it on 129, as MGEG 4 will and Universal HD will be coming off 129 and not 61.5 on some channels.???:confused: :confused:
So, OK give me the numbers to point to 129 - OH don't have them yet? :confused: Says, just hunt around, somewhere between where 148 was and where 110/119 are?
OK.. Can someone shed light on who's B.S'ing? 61.5 does just fine today, but what about Feb 1? If I DO need to re aim to 129, anyone got the numbers??? (from 75287)
Iceberg said:
61.5 will work tomorrow....the channels are mirrored on both 129 & 61.5
Yes, they agree on that... sort of.. but they say MPEG 2 will be mirrored off 61.5, not MPEG4 and that UHD will only be off of 129?:confused:
My order for tommorow morning
DP44 w/301 and 942 on a single wire???
