12/05/2014 18:03 - Uplink Report - 36 Changes | SatelliteGuys.US
Uplink PC
Uplink Report PC
707
6
SatelliteGuys.US DishNetwork Uplink Report - 12/05/2014 18:03 - 36 Changes
Uplink Comparison Range: 12/05/2014 18:00 - 12/05/2014 18:03 (PST)
MAP Changed:
6207(70) - DISH [MPEG4 SD] Nimiq5 72.7W TP 29 ConUS changed to Not Available , map (70) removed (Dish Network Information Channel)(NA)(H)
6207(70) - DISH [MPEG2 SD] EchoStar11 110W TP 10 ConUS changed to Not Available , map (70) removed (Dish Network Information Channel)(NA)(H)
6208(14) - DISH [MPEG4 SD] Nimiq5 72.7W TP 29 ConUS changed to Not Available , map (14) removed (Dish Network Information Channel)(NA)(H)
6208(14) - DISH [MPEG2 SD] EchoStar11 110W TP 10 ConUS changed to Not Available , map (14) removed (Dish Network Information Channel)(NA)(H)
6209(3) - DISH [MPEG4 SD] Nimiq5 72.7W TP 29 ConUS changed to Not Available , map (3) removed (Dish Network Information Channel)(NA)(H)
6209(3) - DISH [MPEG2 SD] EchoStar11 110W TP 10 ConUS changed to Not Available , map (3) removed (Dish Network Information Channel)(NA)(H)
6210(3) - DISH [MPEG4 SD] Nimiq5 72.7W TP 29 ConUS changed to Not Available , map (3) removed (Dish Network Information Channel)(NA)(H)
6210(3) - DISH [MPEG2 SD] EchoStar11 110W TP 10 ConUS changed to Not Available , map (3) removed (Dish Network Information Channel)(NA)(H)
6211(12) - DISH [MPEG4 SD] Nimiq5 72.7W TP 29 ConUS changed to Not Available , map (12) removed (Dish Network Information Channel)(NA)(H)
6211(12) - DISH [MPEG2 SD] EchoStar11 110W TP 10 ConUS changed to Not Available , map (12) removed (Dish Network Information Channel)(NA)(H)
6212(5) - DISH [MPEG4 SD] Nimiq5 72.7W TP 29 ConUS changed to Not Available , map (5) removed (Dish Network Information Channel)(NA)(H)
6212(5) - DISH [MPEG2 SD] EchoStar11 110W TP 10 ConUS changed to Not Available , map (5) removed (Dish Network Information Channel)(NA)(H)
6213(63) - DISH [MPEG4 SD] Nimiq5 72.7W TP 29 ConUS changed to Not Available , map (63) removed (Dish Network Information Channel)(NA)(H)
6213(63) - DISH [MPEG2 SD] EchoStar11 110W TP 10 ConUS changed to Not Available , map (63) removed (Dish Network Information Channel)(NA)(H)
6214(20) - DISH [MPEG4 SD] Nimiq5 72.7W TP 29 ConUS changed to Not Available , map (20) removed (Dish Network Information Channel)(NA)(H)
6214(20) - DISH [MPEG2 SD] EchoStar11 110W TP 10 ConUS changed to Not Available , map (20) removed (Dish Network Information Channel)(NA)(H)
6215(6) - DISH [MPEG4 SD] Nimiq5 72.7W TP 29 ConUS changed to Not Available , map (6) removed (Dish Network Information Channel)(NA)(H)
6215(6) - DISH [MPEG2 SD] EchoStar11 110W TP 10 ConUS changed to Not Available , map (6) removed (Dish Network Information Channel)(NA)(H)
6216(5) - DISH [MPEG4 SD] Nimiq5 72.7W TP 29 ConUS changed to Not Available , map (5) removed (Dish Network Information Channel)(NA)(H)
6216(5) - DISH [MPEG2 SD] EchoStar11 110W TP 10 ConUS changed to Not Available , map (5) removed (Dish Network Information Channel)(NA)(H)
6217(3) - DISH [MPEG4 SD] Nimiq5 72.7W TP 29 ConUS changed to Not Available , map (3) removed (Dish Network Information Channel)(NA)(H)
6217(3) - DISH [MPEG2 SD] EchoStar11 110W TP 10 ConUS changed to Not Available , map (3) removed (Dish Network Information Channel)(NA)(H)
6218(3) - DISH [MPEG4 SD] Nimiq5 72.7W TP 29 ConUS changed to Not Available , map (3) removed (Dish Network Information Channel)(NA)(H)
6218(3) - DISH [MPEG2 SD] EchoStar11 110W TP 10 ConUS changed to Not Available , map (3) removed (Dish Network Information Channel)(NA)(H)
6219(5) - DISH [MPEG4 SD] Nimiq5 72.7W TP 29 ConUS changed to Not Available , map (5) removed (Dish Network Information Channel)(NA)(H)
6219(5) - DISH [MPEG2 SD] EchoStar11 110W TP 10 ConUS changed to Not Available , map (5) removed (Dish Network Information Channel)(NA)(H)
6222(3) - DISH [MPEG4 SD] Nimiq5 72.7W TP 29 ConUS changed to Not Available , map (3) removed (Dish Network Information Channel)(NA)(H)
6222(3) - DISH [MPEG2 SD] EchoStar11 110W TP 10 ConUS changed to Not Available , map (3) removed (Dish Network Information Channel)(NA)(H)
6223(14) - DISH [MPEG4 SD] Nimiq5 72.7W TP 29 ConUS changed to Not Available , map (14) removed (Dish Network Information Channel)(NA)(H)
6223(14) - DISH [MPEG2 SD] EchoStar11 110W TP 10 ConUS changed to Not Available , map (14) removed (Dish Network Information Channel)(NA)(H)
6224(6) - DISH [MPEG4 SD] Nimiq5 72.7W TP 29 ConUS changed to Not Available , map (6) removed (Dish Network Information Channel)(NA)(H)
6224(6) - DISH [MPEG2 SD] EchoStar11 110W TP 10 ConUS changed to Not Available , map (6) removed (Dish Network Information Channel)(NA)(H)
6225(12) - DISH [MPEG4 SD] Nimiq5 72.7W TP 29 ConUS changed to Not Available , map (12) removed (Dish Network Information Channel)(NA)(H)
6225(12) - DISH [MPEG2 SD] EchoStar11 110W TP 10 ConUS changed to Not Available , map (12) removed (Dish Network Information Channel)(NA)(H)
6226(45) - DISH [MPEG4 SD] Nimiq5 72.7W TP 29 ConUS changed to Not Available , map (45) removed (Dish Network Information Channel)(NA)(H)
6226(45) - DISH [MPEG2 SD] EchoStar11 110W TP 10 ConUS changed to Not Available , map (45) removed (Dish Network Information Channel)(NA)(H)
Channels in the system: 9552
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
(FP) = Free Preview
The Format and Layout of the SatelliteGuys Uplink Report is © Copyright 2014 SatelliteGuys.US and may not be republished without written permission from SatelliteGuys.US.
SatelliteGuys Uplink PC Version 1.0.0
© 2014 - All Rights Reserved - SatelliteGuys Incorporated
12/03/2014 12:35 - Uplink Report - 94 Changes
12/08/2014 09:10 - Uplink Report - 6 Changes
