119/110/61.5/129 question | Page 2 | SatelliteGuys.US
Ok Guys here it is:
Long Island NY Zip 11507
Everything with NYC locals
All self installed
110/119 & 61.5 DishPro LNB's - Owned
DPP-44 - Owned
722 Owned
622 Leased (Drive Issues I think is about to die)
501 Owned
508 Owned
I'm not interested in upgrading the 501/8 right now. Is there any way to keep everything I currently have and just add another dish to the current configuration to receive the new HD?
I know 129 is a stretch from here, but if I can see it can I just add that location? If I can't get 129 what are the other options to keep my mpeg2's in the mix?
Thanks to you all
CCash
I'd like to know if I can get 129 as well (Zip 11021). Right now I have essentially your dish configuration (don't know what switch, though) but with two MPEG4 receivers. I think the 1000.4 dish will be too heavy for the chimney where my current setup is anchored (and my neighbor's dishes might block LOS). A 1000.2 would be lighter and point away from my neighbor's setup; while my dishes are pretty high up I'm beginning to think 129 will be hit-and-miss.
a more fundamental question: will a dish 500 pointed to 129 give a stronger signal than a 1000.2 ? [110/119/129]. Stronger as in enough to make a noticeable difference to the average watcher.
no...you may gain (on the new meter) 1 or 2 points
The larger dish on the 1000.2 helps compensate for the LNB being offset
Upgrading to a 1000.2...need input please
EA & retain 110/119?
