wa6rht SatelliteGuys Pro Original poster Lifetime Supporter Jan 11, 2004 255 83 Modesto, CA Jan 6, 2020 #1 Just want to confirm that a 1000.2 hybrid dish will work with a 211 receiver as long as there are no other receivers in the dish correct? Reactions: Rainy99
Bobby Publican Supporting Founder Lifetime Supporter Sep 7, 2003 72,705 29,821 Rohnert Park, CA Jan 6, 2020 #2 You are golden!
wa6rht SatelliteGuys Pro Original poster Lifetime Supporter Jan 11, 2004 255 83 Modesto, CA Jan 6, 2020 #3 Thanks. That's what I thought.
Bobby Publican Supporting Founder Lifetime Supporter Sep 7, 2003 72,705 29,821 Rohnert Park, CA Jan 6, 2020 #4 Just be sure to remove the Hub if you are going from a Hopper to the 211. It should be a straight coax from the dish to the receiver.
wa6rht SatelliteGuys Pro Original poster Lifetime Supporter Jan 11, 2004 255 83 Modesto, CA Jan 6, 2020 #5 Bobby said: Just be sure to remove the Hub if you are going from a Hopper to the 211. It should be a straight coax from the dish to the receiver. Click to expand... Yes, just swapping a Dish 500 out with a 1000.2 and just wanted to confirm that the LNB would work. I though I remembered doing that when I activated my 211 for my RV. Just hooked the receiver straight to the cable from the hybrid dish.
