1000.2 vs 1000.4 dish | Page 2 | SatelliteGuys.US
Justa said:
I actually decided that before your post, and will be going with his decision of the .2 but was confused by his original suggestion for the .4.
Ever since dish came out with the eastern arc twin for the d1k2, at least around here, all you are going to get is a d1k2. Maaaybe you can pay your tech a few dollars cash to dig a banged up d1k4 out if his truck if you really want it.
Directv went to a different kind of mount. It is a stubby mount. No struts required. Directv dishes are a lot larger and heavier than either 1000.2 or .4 dishes. I install all of them. My experience with the stubby mount is they are great. Stronger due to less mass higher in the air. Less ability to be blown around in the wind. I wish Dish would come out with their version of it. It is lower to the roof line and makes a dish less visible. A lot of people like that.
EHD?
component output
