1/30/2011 11:24am - Uplink Activity Report - 37 changes | SatelliteGuys.US
  • Thread starter Thread starter DigiDish Uplink Report
  • Start date Start date
  • Replies Replies 0
  • Views Views 1K
D
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 1/30/2011 11:24am - 37 changes
Uplink Comparison Range: 01/30/2011 11:13A - 01/30/2011 11:23A
Channel Additions:
6807 - UP10 [MPEG2 SD] added to EchoStar8 77W TP 18 ConUS beam (Virtual Channel) (NA)
6808 - UP9 [MPEG2 SD] added to EchoStar8 77W TP 32 ConUS beam (Virtual Channel) (NA)
Channel Removals:
7877 - WGXAD (A) (H) [MPEG4 SD] removed from EchoStar8 77W TP 29 ConUS beam (Mkt:Macon, GA-Macon, GA-N/A)
7880 - WGXA (A) (H) [MPEG4 SD] removed from EchoStar8 77W TP 29 ConUS beam (Mkt:Macon, GA-Macon, GA-FOX)
832 - CNTRO (A) [MPEG4 SD] removed from EchoStar8 77W TP 21 ConUS beam (Centroamérica TV)
853 - DSFAM (A) [MPEG4 SD] removed from EchoStar8 77W TP 21 ConUS beam
863 - PCLAS (A) [MPEG4 SD] removed from EchoStar8 77W TP 21 ConUS beam (De Película Clásico)
865 - CINEL (A) [MPEG4 SD] removed from EchoStar8 77W TP 21 ConUS beam (Cine Latino)
867 - BDMAX (A) [MPEG4 SD] removed from EchoStar8 77W TP 21 ConUS beam (BandaMax)
868 - TLHIT (A) [MPEG4 SD] removed from EchoStar8 77W TP 21 ConUS beam (Telehit)
872 - TR3S (A) (H) [MPEG4 SD] removed from EchoStar8 77W TP 21 ConUS beam (MTV Tr3s)
6883 - UP11 (NA) [MPEG4 HD] removed from EchoStar8 77W TP 29 ConUS beam (Virtual Channel)
19140 - TRIGC (A) [DATA] removed from EchoStar8 77W TP 21 ConUS beam
36702 - MTDT2 (A) [EPG] removed from EchoStar8 77W TP 29 ConUS beam
36850 - DNL8 (A) [143] removed from EchoStar8 77W TP 21 ConUS beam
36852 - DNL11 (A) [143] removed from EchoStar8 77W TP 29 ConUS beam
36853 - DNL12 (A) [143] removed from EchoStar8 77W TP 29 ConUS beam
36854 - DNL10 (A) [143] removed from EchoStar8 77W TP 29 ConUS beam
Channel Moves:
5290 - WTVM [MPEG4 HD] moved from EchoStar8 77W TP 28 ConUS beam to EchoStar8 77W TP 17 ConUS beam (Mkt:Columbus, GA-Columbus, GA-ABC) (A) (H)
5291 - WRBL [MPEG4 HD] moved from EchoStar8 77W TP 28 ConUS beam to EchoStar8 77W TP 17 ConUS beam (Mkt:Columbus, GA-Columbus, GA-CBS) (A) (H)
5292 - WLTZ [MPEG4 HD] moved from EchoStar8 77W TP 28 ConUS beam to EchoStar8 77W TP 17 ConUS beam (Mkt:Columbus, GA-Columbus, GA-NBC) (A) (H)
5293 - WXTX [MPEG4 HD] moved from EchoStar8 77W TP 28 ConUS beam to EchoStar8 77W TP 17 ConUS beam (Mkt:Columbus, GA-Columbus, GA-FOX) (A) (H)
5294 - WJSP [MPEG4 HD] moved from EchoStar8 77W TP 28 ConUS beam to EchoStar8 77W TP 17 ConUS beam (Mkt:Columbus, GA-Columbus, GA-PBS) (A) (H)
5150 - WSIL [MPEG4 HD] moved from EchoStar8 77W TP 18 ConUS beam to EchoStar8 77W TP 29 ConUS beam (Mkt:Paducah, KY-Harrisburg, IL-ABC) (A) (H)
5151 - KFVS [MPEG4 HD] moved from EchoStar8 77W TP 18 ConUS beam to EchoStar8 77W TP 29 ConUS beam (Mkt:Paducah, KY-Cape Girardeau, MO-CBS) (A) (H)
5152 - WPSD [MPEG4 HD] moved from EchoStar8 77W TP 18 ConUS beam to EchoStar8 77W TP 29 ConUS beam (Mkt:Paducah, KY-Paducah, KY-NBC) (A) (H)
5153 - KBSI [MPEG4 HD] moved from EchoStar8 77W TP 18 ConUS beam to EchoStar8 77W TP 29 ConUS beam (Mkt:Paducah, KY-Cape Girardeau, MO-FOX) (A) (H)
5155 - WSIU [MPEG4 HD] moved from EchoStar8 77W TP 18 ConUS beam to EchoStar8 77W TP 29 ConUS beam (Mkt:Paducah, KY-Carbondale, IL-PBS) (A) (H)
9259 - WDKA [MPEG4 SD] moved from EchoStar8 77W TP 18 ConUS beam to EchoStar8 77W TP 29 ConUS beam (Mkt:Paducah, KY-Paducah, KY-MY) (A) (H)
9262 - WTCT [MPEG4 SD] moved from EchoStar8 77W TP 18 ConUS beam to EchoStar8 77W TP 29 ConUS beam (Mkt:Paducah, KY-Marion, IL-REL) (A) (H)
5290 - WOAY [MPEG4 HD] moved from EchoStar8 77W TP 32 ConUS beam to EchoStar8 77W TP 21 ConUS beam (Mkt:Bluefield, WV-Oak Hill, WV-ABC) (NA)
5291 - WVNS [MPEG4 HD] moved from EchoStar8 77W TP 32 ConUS beam to EchoStar8 77W TP 21 ConUS beam (Mkt:Bluefield, WV-Lewisburg, WV-CBS) (A) (H)
5292 - WVVA [MPEG4 HD] moved from EchoStar8 77W TP 32 ConUS beam to EchoStar8 77W TP 21 ConUS beam (Mkt:Bluefield, WV-Bluefield, WV-NBC) (A) (H)
5293 - WVNSD [MPEG4 HD] moved from EchoStar8 77W TP 32 ConUS beam to EchoStar8 77W TP 21 ConUS beam (Mkt:Bluefield, WV-Lewisburg, WV-N/A) (A) (H)
5294 - WSWP [MPEG4 HD] moved from EchoStar8 77W TP 32 ConUS beam to EchoStar8 77W TP 21 ConUS beam (Mkt:Bluefield, WV-Grandview, WV-PBS) (A) (H)
6555 - WLFB [MPEG4 SD] moved from EchoStar8 77W TP 32 ConUS beam to EchoStar8 77W TP 21 ConUS beam (Mkt:Bluefield, WV-Bluefield, WV-REL) (A) (H)
6803 - UP3 [MPEG2 SD] moved from EchoStar8 77W TP 17 ConUS beam to EchoStar8 77W TP 28 ConUS beam (Virtual Channel) (NA)
Channels in the system: 7454
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
(FP) = Free Preview
The Format and Layout of the SatelliteGuys Uplink Report is © Copyright 2011 SatelliteGuys.US and may not be republished without written permission from SatelliteGuys.US.
The SatelliteGuys Uplink Report is powered by Digiblur Technologies! - DigiDish v10.10.28
© 2011 - All Rights Reserved - SatelliteGuys Incorporated
D
1/30/2011 10:09am - Uplink Activity Report - 43 changes
D
1/30/2011 12:54pm - Uplink Activity Report - 1 change
