Or, in Vurbano's case, both!![]()
C'mon now, Vurbano's not that bad, is he?
You either got a misaligned dish installation or you are cursed.![]()
I remember when I was installing my Slimline and HR20-700, I had a bad connector at the reciever. I noticed when it came disconnected, the picture actually froze up right were it was. Very strange. Didn't have to reset the reciever or anything, just repaired the connection.
Sounds like the same issue you are having. Check you connections.
Good luck!
Nothing wrong with the DISH. Its Newly installed. Last tienm I checked all signals were 90-100I agree with misaligned dish at least.
Also connections/cables could be getting wet.
Vurbano, I thought you were going to repeak your dish the last time you had rain issues?
The only thing half empty must be my Koolaid cup.I actually think its his glasses. They are not rose colored and only see things as half empty.
That is truely amazing that rain isnt capable of coming down as hard here as in Houston. Must not be the case today though because I see far more severe thunderstorm warnings and watches in VA than TX.If you're still suffering rain fade you may want to get it checked for bad connections from the dish on down.
It rains a lot harder (most of the time) here in Houston than it does in Virginia and I've only suffered from rain fade when the storms were at their worst toward the Southwest on my 3 LNB dish.
Something is causing your rain fade and, if it's not the dish alignment, leaking connectors are (more than likely) the cause.
Hope this helps, I want you to be a happy D* customer.![]()
That is truely amazing that rain isnt capable of coming down as hard here as in Houston. Must not be the case today though because I see far more severe thunderstorm warnings and watches in VA than TX. NOAA's National Weather Service![]()
You made the statement not me. ANy further discussion of a comparison would require the 2, 5 and 10 year rainfall intensity curves for Newport News and Houston TX.I'm not going to get into another "mine's bigger (or in this case worse) than yours" regarding the rain in Houston vs. Virginia. Suffice it to say it can rain hard at times in both places.
Connections are fine. Nice and checked. If you want to reason with someone next time don't shoot your mouth off with statements like:You just don't (or won't) get it do you?
Trying to reason with you is a little like mud wrestling with a pig, you both get muddy, and the pig loves it.
Now answer my question about why you are so unwilling to check your connectors just so you can continue to bitch about D*.
Its not a good way to start.It rains a lot harder (most of the time) here in Houston than it does in Virginia ........
Intensity and quantitySince you piqued my curiosity I check the National Weather Service historical records for both Houston and Norfolk (as close to you as I could get from NWS).
The National Weather Service has published historical averages (year to year) up to the year 2000 for both Norfolk and Houston
For the historical period 1971-2000, Norfolk's average rainfall was 45.73 inches per year.
For the historical period 1971-2000, Houston's average rainfall was 47.84 inches per year.
The heaviest one day rainfall ever recorded in Norfolk was 8.93 inches.
The heaviest one day rainfall ever recorded in Houston was 14.58 inches.
So who does get the most (and the hardest) rainfalls?
I have some 97's. I dont see how bringing the signal from 97 to 99 is going to keep it from going to zero during a storm. I emailed a fellow OTA forum member last night that said D* was out for him in Chesapeake for 55 mintues during the last Nascar race. I guess he has an equipment problem too?Vurbano, you are close enough to Baltimore, Washington DC, and Raleigh that you should be showing some signal on 99 and 103. My guess is that your dish isn't properly aligned.
Limited time offer
