Is anyone having problems with the 922 program guide. It's been three days since I've had a down load. I am going to G1, 3, the DC light is on, everything seems to be in order.
I've had no problems with my 922 lately. When I see problems I usually unplug the 922 and let it reboot, then I call one of my my program providers NPS or SRL or do an online rehit. Then I force the guide to load. I go to G1-3 and pull up options 6,0,5 diagnostics F and leave it sit there for about 20 min. That usually take care of most guide problems.![]()
Tvroporo,
I have done everthing you have suggested and the guide has come on. I then went to the option 6,0,5 but I coundln't find a diagnosics F. All I can get is diagnostics A. How do I get F?
Al,
That was clear as mud. I will have time tomorrow to sort it out.
Thanks.
I think I've tried this before and had no idea what was going on. I have been watching these numbers for 16 minutes and don't know any more than I did when I started. In the two row of 0s I have 7 and 3 on both lines, is this what I am waiting for to add up to 14? What is considered a column? I see, from the left, a column of double diget numbers, a column of single digit numbers, a column of triple digit numbers with an "a" in front of them. Al, you talked about a number in the 4th row, 4th column being aroing 50, I see one in what I think is the 6th column that has been on 55 since the begining. I am now 24 minutes into this and I am totally confused.
I quit at 26 minutes. I have a guide, so I guess that's what I want. Thanks.
Limited time offer
